跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
Genuie LCD Not working
Please understand my English.
Fake(OEM) LCDs work normally. (Touch and Home Button )
However, genuine LCDs do not work normally. (Touch and Home Button)
According to the repairman, is it true that there is a problem with the backlight pin?
The repairman says there is a problem with this part.
Is it true?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Can you elaborate on your post a little more? Did you get your screen replaced with an aftermarket or an OEM one?
完成的
@hootonberg
Yes, the aftermarket products worked.
However, the playback display does not move.
完成的
@hootonberg
By the way, if you remove the photo mark and connect only one connector, the touch works well.
完成的
添加一条评论
1个答案
已选择的解决方案
Yes I think the repairman is correct although it has nothing to do with the backlight circuit. I don’t know why he couldn’t fix the problem.
 Usually you only need to bend the two ground pins back out at the end of that FPC you have circled as they are usually bent in. If the ground pins are not bent in you might have to remove a FPC pin. I would have to have a look on the schematic to remember which one.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
munbo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 63
