跳转到主内容
From the Inspiron series 15 model 5558 released in 2015 by Dell. A mid-level laptop with a 15.6-inch display and fifth generation Intel processor.
17 个问题 查看全部
Why laptop display is randomly going black but its not software issue?
i have touch display. the screen is going black suddenly. its not the software issue since i checked with other OS. if its display cable issue where can buy display cable? or is there any solution?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @buro ,
Connect an external monitor to the laptop’s HDMI port and check if its’ display stays constant. Even a TV can be used as an external monitor as long as it has HDMI inputs and you have an appropriate cable to connect the two together. Don’t forget to press the F8 key to toggle the display from the laptop only, to the external only or to both on.
If the external monitor display is OK, when the laptop display goes black, try shining a torch at an angle close to the laptop screen to check if there is still an image there. It will be very faint, so trying this in a darkened room may help to see it if it is there.
If there is an image then you have a backlight problem, either due to a faulty LVDS cable or cable connection, a faulty display panel or a fault on the motherboard
Knowing that it is a backlight problem will only help if you wish to get down to board level repairs on the motherboard. That is if it is proven not to be the LVDS cable or the display. If it is determined to be in the display panel it cannot be repaired, the panel will have to be replaced.
If there isn’t an image then it may be either due to a faulty LVDS cable or cable connection, a faulty display panel or a fault on the motherboard.
Also try pressing on the right side hinge (I think) to see if you can make the display come back on again as the LVDS cable passes through the hinge to get to the display assembly and it may be damaged there
Here’s the service manual for the laptop, taken from this webpage. Go to p.73 to view the necessary pre-requisite steps and then the procedure to remove the display assembly. This shows how to gain access to all the relevant components i.e. LVDS cable and the display panel.
这个答案有帮助吗?
得分 1
1条评论:
thank you so much for the response. I checked the display when it goes black, there is a dull image but it wont change or move. Before the display going black it starts getting lines and display starts shaking , after few seconds it goes black.
完成的
添加一条评论
添加你的答案
ravi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 12
总计 400
