跳转到主内容
加入维修社区 - 创建账户
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
iMac won't turn on
It does not work, when opening the iMac from the inside, I found that when I press the power button only the fans turn on and then turn off
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Your previous posting: iMac won't turn on
完成的
添加一条评论
1个答案
已选择的解决方案
It sounds like you need to find someone to help you locally, there is a limit on what we can offer here. Where are you located? Maybe we can aim you to someone.
这个答案有帮助吗?
得分 1
3条评论:
I'm in Palestine
Unfortunately, we do not have companies that support Apple devices, but if you explain to me what are the causes of this problem and what is the solution, I can try it myself or send it to someone who has little experience, but we need someone who explains to us what caused this problem
完成的
Sorry that's just not possible, I would need the system to diagnose it which is just not practical as I'm on the other side of the world!
完成的
thank you man
完成的
添加一条评论
添加你的答案
Msaqqa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 68
