跳转到主内容
The Casio CTK-3000 has 61 keys (5 octaves), about 400 instruments, and a built-in metronome.
Static in right speaker and low volume in left speaker.
Hi. My father has a Casio CTK-3000 which he has owned for a few years. He turned it on today for th first time in several months and now there is static in the right speaker and low volume on the left speaker. We've tried connecting to an amp and the static is still there. We have even tried plugging it into a different outlet and still the same result. While it was not being used, it was covered.
Does anyone have any ideas what might be causing this. Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Internal wires or cut or severed. It is toast. That happened to mine 6 months ago.
这个答案有帮助吗?
得分 0
1条评论:
Sorry to hear that tho...
完成的
添加一条评论
Try check and replace the op amp after the DAC output. I fixed a Yamaha piano having the similar issue. One of the troubleshooting method is to probe the signal directly from the op amp output pins of both left and right channels to see if it's any abnormality in the sound.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Yves 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 591
