跳转到主内容
1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
147 个问题 查看全部
Power issues, not recharging or switching on
My computer was initially not holding a charge and warned me that the battery needed replacing. I procrastinated replacing the battery, it stopped recharging intermittently and wouldn’t always turn on. I took it into Simply Mac and they ran diagnostics and told me I needed a new I/O board but I had to order one from a 3rd party, yada yada…
So I skipped spending the coin at simply mac and replaced my I/O board and battery myself. I wasn’t particularly impressed with the “new” (refurb) I/O board as it has signs of corrosion on the port (I had to get it from someone other than ifixit as they were out). Got the replacement I/O board and battery in and for a while I was a happy camper… I still noticed some issues. Like the computer would only charge with the charger oriented in one direction and sometimes I would have to tweak it a certain way to get the little light on the charger to turn orange to get it to charge.
Now computer has stopped charging completely and once again I’m unable to turn my computer on. Is the replacement I/O board that I installed faulty..? Or is something wrong with my charger? Or is it something else?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Lets go through the basics:
Review this Apple T/N Apple Portables: Troubleshooting MagSafe adapters Make sure the MagSafe cord is not damaged. If it is you’ll need a new charger. Also make sure the systems contacts are clean and gold colored, not black!
Make sure you have a real Apple charger, there are a lot of fake units which can harm your system and you! OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth This is why the contacts can be black Lacking safety features, cheap MacBook chargers create big sparks
The last step is to monitor your battery and charger using this gem of an app CoconutBattery Take a snapshot of the apps main window and post it here for us to see [在已经存在的问题里加入图片|
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ross Lesslie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 23
