跳转到主内容
鉴定方式: 型号 M8541 / 5 或 10 GB 硬盘 / 转盘会旋转
29 个问题 查看全部
How do I connect iPod Classic 1st Gen to Windows 10 PC?
I have a couple dozen iPod first gens, and need to test them for my job. I have a firewire cable and a firewire wall charger. I also have a firewire to USB adapter but when I plug in the iPod to my PC a message comes up saying it shorted out. How do I connect iPod Classic 1st gen to my PC??
Windows 10 Pro
Intel(R) Core(TM) i5-4590 CPU @ 3.30GHz
16GB Ram
64-bit OS
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hi Gil Johbet
just thinking if you have another spare firewire cable to try out. or perhaps suggest you to get pci-e firewire card, i feel it would be stable in this way.
somehow did you tried with the firewire to usb before ? does it work?
i am skeptical on this
这个答案有帮助吗?
得分 0
4条评论:
I don't have spare cable, yet. Are the cards easy to install into a desktop?
I've never used firewire to USB before. I was hoping it'd be the easy solution to my problem.
完成的
let me know what mainboard are you using.
if you mainboard has pci-e... that is good.
yep it is easy to install.
normally for desktop,
shut down and off the power
just open up the computer casing and remove one of the protection bracket which is normally held with a screw.
align and install.
https://www.youtube.com/watch?v=tZBdH8kt...
below using older pci but you can watch it for an idea.
https://www.youtube.com/watch?v=Qrim4XTH...
完成的
[image|2056515] This is what I see, so I should be able to purchase this https://www.amazon.com/QNINE-Firewire-Ex... correct?
EDIT: I have pci express ports
完成的
@Gil Johbet yep thats great, that is it.
完成的
添加一条评论
Tried this before! Gonna need a mac to use a 1st gen pod
Even with a few adapters my 17 MacBook Pro somehow works and syncs with my 1st gen pod
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gil Johbet 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 20
总计 1,375
