跳转到主内容
发布于2017年6月,iPad Pro 10.5寸替代发布于2016年的iPad Pro 9.7寸。
134 个问题 查看全部
My iPad pro 2017 10.5 bent
Update
Sorry it took me so long to post, these are the pictures of how it is now, I’ve already tried to bend it back but I’m to scare of making it worse
Hi, I have an iPad pro 10.5 2017 that I recently bought, the problem is that I dropped it from my bed and now it is bent on the top right corner, the display has a thin “hairline” inside the screen that is barely visible but that’s another problem.
The side of the screen with the bent does not stick anymore to the frame(you can see the backlight from the side), is there anything that I can do about that without buying the back case for the ipad?.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Sorry it took me so long to post, these are the pictures of how it is now, I’ve already tried to bend it back but I’m to scare of making it worse[image|2111785][image|2111786]
完成的
添加一条评论
2个答案
If you’re willing to tear it down, you might be able to bend it back into place. Unfortunately their choice in thin aluminum does bend quite easily, especially in the 2018 and newer models. I would get a protective case for yours as well.
这个答案有帮助吗?
得分 0
2条评论:
Can it be done without touching the battery?
完成的
Post some pictures so I can get a better look at it please. You should be fine but I wanna make sure that's all
完成的
添加一条评论
I think yes you should try to bend it back but just a heads up that I have the same iPad and this happened to me and it was hard to bend back. You will need to have very strong hands
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
fede 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 823
