跳转到主内容
Repair guides and support for carpet cleaners of the upright, steam cleaning, and hot water extraction styles.
57 个问题 查看全部
My hoover dual power max will only suck up water with upholstery tool
I have only had it for a year, usually works great. Recently got it out to clean the carpets and it wont suck up water. Thoroughly clean the unit and checked all hoses and filters to no avail. However, I put on the upholstery attachment and it works like a dream. But I cannot do all my carpet with that, it would take forever. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
In some of these units, there’s a dial that switches a valve essentially. Do you have that set in the right position?
这个答案有帮助吗?
得分 0
添加一条评论
I dont have the option of a dial to change valves, no
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem, and I found the solution by reading a detailed guide available at how can I use hoover carpet cleaner
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rachel Huffman 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 60
总计 2,959
