跳转到主内容
在2015年3月发布,于2015年4月10日开放购买,Galaxy S6 Edge是Samsung最新的旗舰智能手机的曲面屏幕版。
237 个问题 查看全部
What is this on the motherboard that broke?
There is this “ground pin” look a like, that broke of the motherboard, and I do not know what it is. I tried to solder it, but the bottom of the “pin” just came lose. Will the device function without it, and what part will lose functionality? It connects to the midframe of the galaxy.
Can I connect that “ground pin” directly to the side of the resistor?
In the schematic it says ANT4003, does it connect to the top part of C4047?
Part code 3712-001564 , related to BT/WIFI. How to fix this nightmare?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
You'd need the solder skills of a super genius to attempt fixing that... Try following the schematic to whatever component that lead goes to (nearby or flipside), then solder a wire to that and connect to the frame
完成的
添加一条评论
2个答案
If you wanna fix it, you’re going to want to find someone who is skilled in microsoldering. I’m looking at the teardown on ifixit and it looks like it’s just a grounding pin. With there being multiple ground points in these phones, you should be able to get away without it.
这个答案有帮助吗?
得分 0
添加一条评论
I managed to superglue one side of the ANT4003 onto the motherboard so it would stay where it should be, and the other end I soldered to the C4047, since it looks like it’s connected to it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shane 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 51
