跳转到主内容
苹果2019年度的旗舰手机发布于9月20日,该设备配备5.8英寸OLED显示屏、三颗后置摄像头,电池续航能力大幅度的提升。为iPhone XS的后续机型。
149 个问题 查看全部
Bent pins in lighting port, faulty?
Hi All,
Since I bought this iphone 2 months ago , the lighting port felt very stiff.
Under a closer inspection today I noticed the pins are not even and look bent. Is this normal and within specs ? So far It works well, but I don’t know wether I should be concerned about it..
Update (04/09/2020)
After watching the iFixit video where it show how to replace the lighting port I have my doubts about getting it serviced . There’s silicone all over the phone and around the screen being removed which is not reapplied during the re-assembling. So I understand the phone won’t be up to original specs ( sealing is lost around several parts ) after the repair.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I would get that repaired. You can call around local repair shops to see if they’re open. Make sure they use a premium OEM port and not an aftermarket as the X and above get real picky when it comes to aftermarket parts.
这个答案有帮助吗?
得分 1
3条评论:
Many thanks for your reply. I just chatted with apple and they said they need to have it inspected by a technician to determine wether I damaged it or not and they would send me a quote if they think I caused this damage which which I obviously did not. I’m very disappointed...
完成的
They'll most likely charge you for a replacement but we'll have to see. Like I said, you can call around your local repair shops to see if they can get it done quicker. And the ports are replaceable on these phones you don't need to replace the whole unit.
完成的
Many thanks Jesse for the help. Have a great day.
完成的
添加一条评论
添加你的答案
Fendrix 69 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 61
总计 2,786
