跳转到主内容
The Grand Prix was updated for 2004 on a revised version of the GM W platform and was unveiled at the 2002 Chicago International Auto Show on February 7, 2002 as the Grand Prix G-Force Concept.
20 个问题 查看全部
Why does car spit n sputter and barely runs
I have an 05 Pontiac Grand Prix with 3.8 series 3 V-6 engine. I washed it and it started spitting n sputtering bogging down, I barely made it home. What would cause this? Is it the fuel filter, where is the fuel filter
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Oil….Check and make sure it is not clumped up… Water could have also gotten into your engine….
这个答案有帮助吗?
得分 0
添加一条评论
As oil levels and quality is important to the viability to engine performance, I don’t believe that is the cause of this issue. Sounds like a fuel/spark issue. It could be as simple as a loose spark plug wire or as serious as a timing chain skipping a tooth due to a chain guide malfunction. Check the basics first, check connections, coils to spark plug wires, wires to plugs etc.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
brody nicolaisen 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 8
总计 171
