跳转到主内容
加入维修社区 - 创建账户
针对配备 4G LTE 的第五代 Apple iPad 的维修指南、拆解和故障排除信息,有 32 GB 或 128 GB 存储空间版本可选。于 2017 年 3 月发布。型号为 A1823。采用 9.7 英寸视网膜显示屏和 64 位 A9 处理器。
iPad 5 Not Charging
I had a customer bring me an iPad 5 that doesn’t charge. I managed to get it to charge at 1amp sometimes but most times it charges at 0amps…
I checked vchargr and it was showing 4.2volts.. I changed Tristar and now the line shows 5 volt and I also changed charge flex and that didn’t do anything either…. So I tested vbatt on battery connector while plugged in and it shows 1.4 volts instead of 3.7 volts. I looked at a schematic board view for an iPad Air and they are totally different…
I plugged cable in without battery and the amperage goes to about 0.12 amps 0.15amps 0 then moves around but when I plugged battery back in and it boots, it goes back to 0 amps…
Did I install Tristar wrong or is something on vbatt line bringing the voltage down.. When the iPad boots, an I have cable plugged in, it says unlock device to use accessory then starts charging at 0.5amps which should be 2 amps…
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This is me the author from above.
i am just letting everyone know that I replaced tristar again with a new one and the iPad charges again!
just thought I’d let everyone know in case someone has the same issue as me. Make sure tristar is working !
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daniel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 15
总计 514
