跳转到主内容
加入维修社区 - 创建账户
10.1" tablet released in February 2014, powered by a custom version of Android 4.4 KitKat, and identified by model number: SM-T520NZKAXAR
When my battery is disconnected it gives 3.7
But when I attach it to the mother board it's shows 0 volts …what testing should I do to find the problem just bought my first multi meter so i am still learning , want to fix this for the grandparents to have
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
  1. How old is the device or battery
  2. Without any load it may show 3.7V but with load it may fail.
  3. Connect battery to tablet - close device - start it - does it work for at least few minutes
  4. Do (3) then, connect to charger and the press powerbutton.
  5. Can you see the manufactured date in the battery? If it is more thant 3 years - may be better to get a new battery. Search eBay or aliexpress.
(Do not connect to charger without battery - some devices can brick)
这个答案有帮助吗?
得分 0
3条评论:
I bought the battery last year
After the original one wasn't holding charge , then eventually stopped working wouldn't turn back on
No charge light
Hasn't worked for a year
完成的
So the device is the currently dead? It was not working for last 1 year.
Then see here:
https://forum.xda-developers.com/galaxy-...
Hope fully other device owners can help you.
完成的
Thanks for your help , I will check them out
完成的
添加一条评论
添加你的答案
Danielle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 25
总计 402
