跳转到主内容
加入维修社区 - 创建账户
Camera failed after software update
Hello all,
So after the recent Samsungs update, my camera functioned fine until a few days ago where I opened it to take a picture of something. The camera froze and I closed it through the multi task bar, and when i went to go open it again i now get a “WARNING; CAMERA FAILED" error everytime I open it. None of my other camera related apps work either now, such as snapchat as it tells me it can't open the camera. I've tried clearing my cache, tried soft and hard reboots, and still nothing. Any ideas?
Update (03/30/2020)
No a factory restore is the last thing I want to do. I've tried the safe mode option to and the camera still fails to open.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Anyone? Need help ASAP.
完成的
I have the same problem…..I even did factory reset but no luck …..I have no hopes left…..
完成的
添加一条评论
1个答案
Hi,
By “hard reboots” do you mean a factory restore?
If not try starting the phone in safe mode and see if the camera works.
If it does then a downloaded app is the cause. The trick is to find out which one.
If still no good try a hard reset (factory restore)
Be sure to backup the phone first to the cloud or a PC otherwise you will lose all your data and downloaded apps.
If it works then restore the phone with the backup and try again
If still no good try reloading the firmware using ODIN - look online for how to do this.
If still no good you have a hardware problem - maybe just coincidental to it happening after the update. Was the phone dropped?
这个答案有帮助吗?
得分 0
2条评论:
No a factory restore is the last thing I want to do. I've tried safe mode as well and it still fails to open.
完成的
@7LineArmy 7
It might be the only way to prove it is a software or hardware problem, but your choice
完成的
添加一条评论
添加你的答案
7LineArmy 7 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 771
