跳转到主内容
Replacing the motherboard ribbon cables ¿Are the cables the same?
Hi!
I’m trying to replace the two ribbon cables between the motherboard and the keyboard of my laptop.
Now don’t turn on.
I have doubts about the replacemant cables that I have got. There are diferences from de originals (see attached images). Aditional number E319831 not appear on the new one, green words vs blue words and the alloy seems diferent.
Do you know if the cables that I buy are correct?
Thank you very much.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
it should work if the pin count and lengths are the same. go for it
这个答案有帮助吗?
得分 0
1条评论:
Thank you for the answer!
I'm worried about the alloy... I tested with a multimeter and I can see that the voltage read with the old cable is pretty higher than with the new one. Thanks!
完成的
添加一条评论
添加你的答案
Jordi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 182
