The throttle will not return to full idle.
After cutting, the throttle will not return to full idle. How to repair?
If by now you have used this unit for two seasons, you will have to replace a muffler.
Two cycle engines will produce more afterburn and will eventually clogged the muffler. Result, an engine that will not idle. In my case the fix was an easy one. I drilled a couple of holes in the muffler. It is not a warranted repair. But it did work for me. Thanks for asking. Matt of Martins TV Repair.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 212
Throttlewillnot return all the way
由 Joe Godfather 完成的
