跳转到主内容
Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
342 个问题 查看全部
Came with Seagate Hard Drive, find 2TB replacement?
My Mid 2010 i3 3.2GB 21.5" iMac has a 1TB Seagate ST31000528AS. I have to replace HDD's with the same manufacturer for the thermal sensor, right?
Where can I find a Seagate 2TB HDD that I can swap out with the original?
Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Yes you are correct this does need same manufacturer. I believe also it must be of the same series, which means you are going to want to find a drive to the tune of ST32######AS. I saw a few for reasonable prices on Newegg. I believe this is what you are looking for.
这个答案有帮助吗?
得分 4
2条评论:
If you are having problems with your current hard drive it is still under warranty by Seagate.
完成的
Always have clear and informative answers. +
完成的
添加一条评论
Thank you for the reply, that explains what I need to know.
Nothing wrong with the current HDD, just need more space.
I'll pop over to Newegg and check it out.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dave 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 1,787
