跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
Can I use lithium ion battery soldered to pins
Switching out batteries last night and I one caught fire. Long story. I cannot order parts at this time so I have a iPhone se and a 2000mah battery that isnt a replacement battery but it will fit in the phone. I’m wondering if it’s possible to solder wires directly to the battery connector and use it to power the phone.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Short answer: Yes, it is possible. There are cables for testing iPhones that literally just hook power and ground to the connector. However, the battery does have ICs in it that communicate with the phone about things like battery percentage. Because of this, I would say your best bet if the phone is to be used long term would be to try and desolder the circuit from the exploded battery and connect it to the working one. Then it can be connected like normal.
这个答案有帮助吗?
得分 0
1条评论:
Also, the phone will reboot every couple of minutes if you do not include the battery data (ie power and ground only)
完成的
添加一条评论
添加你的答案
Brayden S 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 6
总计 58
