跳转到主内容
Thin, light and powerful with incredible sound and Wi-Fi capabilities is what everyone needs to have on the go.
45 个问题 查看全部
What size are the screws for this laptop?
My laptop has been losing screws over time and now I only have 4 left out of 9 and feel like it’s going to fall apart! I have been trying for a while to replace them but have struggled to find the size or somewhere that specifically sells these screws that’s available in Australia or ships to Australia.
Could someone tell me the size of the screws for the ASUS Zenbook UX303L? I know the centre screws are shorter than the rest. I think I need the thread length, head thickness, head diamater and drive type.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @maddysims39 ,
Here’s an image showing the screw sizes and part numbers of the screws for an Asus UX303L.
Search online using the Asus part number only in the search term if you have trouble finding them otherwise.
(click on image to enlarge for better viewing)
Hopefully this isof some help.
这个答案有帮助吗?
得分 1
2条评论:
Thanks for this! But do you know which screws from that list are the ones I need (at the base of the laptop)? From the images none of these look like they will fit, as it is a 6 pointed star
完成的
@maddysims39
The screw head is called "torx" and the screws are metric. All standard stuff.
The replacement screws do not have to be torx. Phillips head is fine.
The first number is the diameter, the second the threaed pitch and final the length
For example M2 x1.25x30 reads 2mm diameter (bolt part not head), 1.25mm thread pitch and 30mm in length.
As for your length just measure the length of one of your 4 screws you have left.
Australia is metric, as most countries are, so you should have no trouble buying them there.
When I did a Google Australia search for "metric screws australia" there were quite a few locations listed such as:
allfasteners.com.au
anzor.com.au
etc., etc.
Let us know how you go mate.
完成的
添加一条评论
添加你的答案
Maddy Simioni 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 32
总计 2,124
