My MacBook Pro 15" Touch Bar Late 2016 screen flicking...
My MacBook Pro 15" Touch Bar Late 2016 screen flicking. Is this “OS” problem or Hardware Problem ??…..
The video is not very clear, but I think I see your issue. The top and bottom edges have a problem with the first 1/4” to 3/4” If that is correct, we’ve seen this before. What you are seeing is over and under scan of the horizontal most people note the darker edges vs the strobing.
Sadly, this is a display issue within the T-CON board. So far the cause is over heating of the system.
You’ll need a new display assembly MacBook Pro 15" Retina (Late 2016-2017) Display Assembly following this guide 2016 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换
这个答案有帮助吗?
To add to this you should install a good thermal monitoring app like TG Pro it can help in identifying the problem before the damage and can help in reducing the problem as you can push the fans RPM to offer more effective cooling for heavy processing loads.
It won't help you if your vents are blocked or if the systems fans and fins are clogged up with dust.
These newer systems need yearly inspection and maintenance to clean out the dust build up.
The same problem w/ my MBP 2016 13”
See this article: Apple knew it was selling defective MacBook displays, judge concludes
这个答案有帮助吗?
Sadly, Dhanu Sam issue is different!
The stage light effect you see in the image in the article is the FlexGate issue Here's more on it The Design Flaw Behind MacBook Pro’s “Stage Light” Effect and this 2018 MacBook Pros Try to Solve Flexgate Without Admitting It Exists
The issue seen here is a T-CON problem! Sadly it too will require a new display assembly as the T-CON board is part of the assembly.
This often happens from overheating either due to blocking of the vents or running heavy work loads.
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 16
总计 943
1条评论
please answer me soon ......
由 Dhanu Sam 完成的
