跳转到主内容
Repair guides and support for carpet cleaners of the upright, steam cleaning, and hot water extraction styles.
57 个问题 查看全部
Why is my cleaning solution draining out even when my machine is off?
I have a Hoover SmartWash+ carpet cleaner. I absolutely love it, however halfway through the first time I used it, the cleaning solution started draining out even when the machine is turned off.
There is nothing in the troubleshooting guide that even mentions it at all.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
I also had issues with it continuing to drain out while off and stored away, leading to what I found to be permanently damaged tiles in the basement. I seemed to solve it by doing a big clean; removing the tanks, wiping down the contacts, taking off the front nozzle and rinsing out then using a flat drain cleaning tool to scoop out anything that is left inside, and lastly opening the hose connection port and cleaning that out of anything that had been stuck in there as well. That seemed to do the trick and it didn't do it again since. I usually just do a rinse of the front nozzle scoop to keep that clear as a general precaution.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Char Upchurch 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 99
