Single or Duel Rank which to choose?
This question for Mac Mini 2020 (Assuming 2018+ Is the same).
I’m looking to upgrade Ram to 64Gb. Should I use two of Single Rank 32Gb (Here) Or Two Dual Rank 32Gb?
which is better to use and why?
Thanks
Apple uses single rank SO-DIMM’s,
Both the 2018 & 2020 Mac Mini’s use the same 260-pin PC4-21300 (2666 MHz) DDR4 SO-DIMM’s (x2)
Before you go to the expense of pushing this system to 64 GB you maybe unable to leverage all of this RAM. Video & music production is about the only apps that can, But to be honest the artist I setup systems for often find 32 GB is really the ideal and getting a large internal storage 1 or 2 TB being a better setup (balance). Most have been going with iMac Pro’s as the Mac mini’s GPU is quite limited. The two 2018’s that I setup used external GPU units as they where holding out for the Mac Pro’s but needed something in the mean time.
这个答案有帮助吗?
I have a 2018 model Mac Mini i7 with eGPU (Razer Core X and Radeon RX 560). The computer has upgradeable RAM but it requires specialized tools and disassembly so I only wanted to do this once. I think once 64GB modules come around (i7 Apple uses in Mini supports 128GB of RAM max) I’ll be using Apple Silicon based Mac by then.
Original it has come with 8GB of Single Rank (1R) memory by Micron (2 4GB modules).
Theoretically 1R module should be faster than 2R.
I could not find a 32GB 1R module and installed Double Rank (2R) modules instead.
I am using Samsung M471A4G43MB1. So far no problems, I have not noticed any slowdowns due to 2R as I tested by creating a RAM disk and running Blackmagic Disk Speed Test. The system overall is more responsive under load as I was getting unresponsive episodes with 8GB once I opened too many things. From my experience get as much RAM as you can afford as that creates a little bit of future proofing. But even now I am using most of the RAM as I process footage from GoPro Fusion or edit clips in iMovie - I see not only memory being used by apps, but also Cached Files which greatly speeds up the feel of the system.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 2,666
