跳转到主内容
Also known as the m300, the Clip is a simple MP3 player by SanDisk released in 2007.
16 个问题 查看全部
How To De-Solder A 48-Pin NAND Flash Memory Chip and Recover Files
I have several Mp3 players (3 Sandisk Clip Zip + 1 Agptek A02) and over the years every one of them has been through the wash.
There are lots of audio recordings, and other audio files I would like to recover, but all the players are completely unresponsive. They won’t power on or do anything.
I have tried multiple times to connect them to my computer using several USB connectors (to ensure It isn’t the cable) but nothing happens. My computer won’t even register them being connected.
Using a multimeter, I tested the + and - solder points while one player was plugged in, and there is voltage flowing to the battery—not that that would make a difference one way or the other. The batteries will charge, but that’s about it.
I have watched multiple tutorials, trying everything possible, but so far nothing has worked, and the Mp3 players are still unresponsive.
At this point, I think the only thing that might work would be to desolder the 48-pin NAND flash memory chips (whatever they are called) from my Sandisk Clip Zips, and transfer each to a Sandisk USB drive with the same gig. I saw a few videos where someone was able to recover files from a cracked USB stick by desoldering the memory chip using a reworking station and transferring it to another identical USB drive. They were able to connect it to a computer that way.
I think you can buy 48-pin USB socket/adapters or buy parts from eBay and rig together a USB reader of sorts, but I’m not sure how to do that.
If you happen to know what would be the best way to recover the audio from these players, I would be very grateful.
Also, can all 48-pin chips work on different gig USB sticks? I mean, my Sandisk Clip Zips are 4gb, and my Agptek is 16 gb. Could I transfer the 16gb memory chip from my Agptek to a 4gb Sandisk USB drive so I could use the same USB drive for all (assuming that method works)? Or do the chips strictly work on boards meant for the same gig/manufacturer?
Any input would be appreciated.
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
If you’re trying to DIY this repair, don’t attempt yourself. Data recovery and microsoldering require a lot of skill and knowledge to do properly. Check with iPad Rehab or Rossman Repair Group or even Drive Savers. Jessa of iPad Rehab and Louis of Rossman Repair are both renowned and skilled technicians. They both have youtube channels if you wish to check them out.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
G. Luis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 34
总计 847
