跳转到主内容
Repair guides and support for LED, LCD, HD and other Vizio TVs.
932 个问题 查看全部
LCD replacement for V-Series 50" Class 4K HDR SmartTV VIZIO V505-G9
LCD replacement for V-Series 50" Class 4K HDR SmartTV VIZIO V505-G9. i’m trying to replace my digitizer or LCD for my tv but can’t find a website that are selling them, please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi,
You may be lucky to find one.
Since a broken/cracked screen (if this is the problem and not that is is just a display problem as such) then it won’t be covered the warranty even if it is still valid, anyway.
Disconnect the power from the TV and remove the back cover from the TV and find the LCD panel part number which should be printed somewhere on the back of the panel itself.
Search online using the part number to hopefully find suppliers of the part.
You may find that a replacement panel costs nearly as much as a new TV, so an option to consider is to advertise the TV as faulty, cracked screen - good for parts to try and recoup some of the cost towards a new TV.
Replacement TV boards are always being sought after by others that have a TV with a good screen but a faulty board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alex's Stalker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 2,315
