跳转到主内容
加入维修社区 - 创建账户
2.3L 4cyl or 3.0L V6, 6th Generation
Why won't my car start?
I have a 99 Honda accord. It won't start, but it makes noise like it's starting. The key also keeps getting stuck in the ignition and when I looked under the hood it was leaking, but I don't know what it is or where it's coming from.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Make sure your car shifter is correctly positioned on park or neutral. If it’s not, that might prevent you from removing the key from the ignition. Also make sure the key is in the off position completely and try to wiggle the key while at the same time wiggling the steering wheel. If none of that works, you might have a problem with your ignition cylinder. I’m not sure why the car is leaking. Maybe power steering fluid? Does your steering wheel move freely?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
cookie cosplay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 62
