跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1697 个问题 查看全部
PS4 randomly shuts down
Hi folks :-)
PS4 Shuts down for no aparent reason. Just before it shuts down, for around 1/4 second the picture becomes gibberish.
System has latest updates, and has been restored and initialized. Tested with known god powersupply. The system is very clean. I have triet to apply tension on APU with washers. WIFI vs. LAN makes no difference. It can work for 30 seconds, up to 10 minutes. Safemode will also sometimes crash. Have tried different HDDs and fresh heat-paste has been applied.
Im out of ideas, other than attemting reflow og rebslling of APU. But I mainly suspect RAM-chips, due to the randomness, and the gibbberish seen on screen. Also there is some error code when starting up, but not always. Tried powering directly to mains without power-brick.
When the system shuts down it will stay off until I press the power buttton. Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Did you try to relocate it to another room? Maybe there is some electromagnetic interference in the current room. Try to drain the console fully from power by disconnecting the AC cord and holding the power button for 30 seconds. Check that there isn’t any dust on any connection pins where the HDD and motherboard meet. Clean the connection just in case. Try running every option in safe mode. Try to run games from the HDD and Blu-Ray to see if there is any difference. I had a similar problem with my PS3. Turned out that the Blu-Ray was faulty.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gunnar Alvheim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 42
