跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
iPhone 6 won't connect to computer
I have an iphone 6 which is on the ‘restore to itunes‘ screen. Plugging it in to the normal outlet charges the phone totally fine. However, if I try to connect it to my windows laptop, it charges for a small second and then it stops charging. It also does not show up in itunes. I used the same (original apple) cable and other USB devices seem to work fine (suggesting there is nothing wrong with the USB on my laptop). Does someone know the issue or is there someone who can explain this or help me fix it.
I have cleaned the charging port and disconnected / reconnected the dock connector on the motherboard but it does not seem to fix the issue.
Help would be very much appreciated! Thanks.
Edit: Earlier it showed a message saying something like ‘authorize accessory’, but for that I had to log in, but I didn’t have the passcode.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
There could be a couple of reasons that is’s not connecting to a computer.
The first option it to try with new dock even temporally to rule out.
Secondly the Tristar is another common problem which is a USB communication IC that may have failed to bad chargers or power surges.
If Tristar is the problem you will need a board repairer to take a look and confirm.
Cheers
这个答案有帮助吗?
得分 0
添加一条评论
Call around your local repair shops and see if they can test or repair tristar. There is a tool which can test tristar that some shops will have.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Elias 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 116
