跳转到主内容
This is the Asus - VivoBook X540SA-BPD0602V 15.6", (1366x768) Laptop which contains an Intel Braswell Quad Core N3700 1.6 GHz processor that supports turbo up to 2.4 GHz. It contains 4GB of RAM and a 500GB hard drive.
15 个问题 查看全部
Why is my dads laptop so laggy its brand new
i have this asus vivobook x540u so my dad bought this laptop for his business but after he pressed the power button it boots fine but its took a long time i was wondering should i uninstall this asus apps this the laptop why i hated i3 so much so the specs are intel core i3 7th gen 1tb hdd 4gb ram i said to my dad thats a decent specs for a laptop but its so freaking slow even roblox it cant handle it properly it keeps crashing so since my dad bought a desktop pc im the one whos using the laptop now. Plss give me recommendations
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
Hi,
You can remove most of the Asus apps, just make sure you don’t remove any that are essential to any hardware.
It might also be worth checking the condition of the hard drive by running something like HDDScan, even new disks can be faulty.
Also install a lighter weight anti-virus program. Try Bitdefender for example.
All the best,
Alan
这个答案有帮助吗?
得分 2
添加一条评论
Try un-installing any pre installed software that you don’t need. I had this problem a while a go and sometimes factory resetting it helps (Make sure you have everything backed up). You could also try upgrading the RAM or replace the HDD with an SSD. I have upgraded the RAM on a few laptops and they all seem pretty easy to do.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Alvin Gabriel Mendizabal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 327
