跳转到主内容
加入维修社区 - 创建账户
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
ipad stuck in loop of doom
My ipad 2 is stuck in the reboot loop. It does nothing on its own and when plugged to a charging point, the red low battery sign comes and then the apple logo and it repeats infinitely.
I have tried to charge it for a whole day , but still no change.
When I tried to restore and update it , (by first holding the home button and the power button for few seconds and when apple logo comes, holding only the home button),
my Mac says it is trying to restore my ipad, but next moment i get an error saying
“Ipad can not be restored. an unknown error (2015) occured.”
Can some one please help me ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
According to iPhone 5s restoring gives error 2015; screen is broken, 2015 is an error regarding the internal power of your battery which should be replaced.
Couple of questions:
Are you using the original cable & charger (at least 2A)?
How long has your battery been? Are there any signs of battery wear?
这个答案有帮助吗?
得分 0
2条评论:
I am using original cable and charger..
the iPad i bought around 7 years back. So quite old. It was left unused for last 1-2 years.
How to check if there is any signs of battery wear?
完成的
7 years, and 1/2 years of no usage. I'd say the chances of a battery problem is ridiculously high. Try to remember back 2 years ago, any of these symptoms? https://www.androidcentral.com/how-tell-... . If you forgot, best is to take to a technician, ask them to replace your battery. Best, you get it all working. Worst, you lose nothing (since they can't charge you if they don't repair it anyways).
完成的
添加一条评论
添加你的答案
Sam Rout 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 540
