跳转到主内容
Repair guides for the Xiaomi Mi Mix 2S smartphone. Released 2018, April.
7 个问题 查看全部
Damage Assessment and Advice on Replacement
I, unfortunately, dropped my Xiaomi Mi Mix 2s. Though I had a screen protector and a durable case, it hit at the right spot and annihilated a piece of the side. It broke the screen and the LCD as it pooled. However, a sizeable chunk is gone and I do not know if I need to just replace the screen and LCD or if the whole frame is too far gone as well. The good news is that the battery works but I am nervous about taking apart my phone as I am afraid of buying parts for a phone that may be ruined. Should I spend the time trying to replace the phone (and if so what kits should I look at?), or should I invest in another phone (which would have to be a less expensive one)? Let me know what you all think.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi,
The only way to really tell is to dis-assemble the phone and assess what physical damage has occurred to the internal components.
Post some images of the damage back here. Here’s how to do this. 在已经存在的问题里加入图片
If it appears to be reasonably OK then as a DIY repair all you can do is to temporarily replace the LCD screen assembly and then check the operation of the phone to see what else if anything is wrong and re-evaluate whether it is economically viable to continue the repair.
Until you can “see” what is happening it would only be guesswork.
Here’s a link to the ifixit 小米 Mi MIX 2S 屏幕总成更换 guide which may be of some help.
Alternatively if this seems too daunting contact a reputable, professional mobile phone repair service and ask for a quote to repair the phone and then depending on the answer decide if it is worth it. This will cost you but in the end it may be the cheaper and quicker option.
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
Xiaomi Mi Mix 2s 屏幕图片
指南
小米 Mi MIX 2S 屏幕总成更换
难度:
中等
25 minutes
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hayden Cunningham 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 105
