跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Why does my phone only work when I heat it up with a hairdryer?
Hello! Recently my iPhone’s touchscreen stopped working and it only works for 2-3 minutes after I blow the back of the iPhone with a hairdryer for 1 minute. Is there a way to fix my iphone? Please and Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
I have an android, but the same problem......
完成的
I'm using Samsung M02s, it has the same problem. It only works between 9am - 6pm. Sad Life
完成的
添加一条评论
1个答案
Hi,
Very strange, I’ve repaired a lot of phones but never come across this! I will go through the steps I would try to diagnose the phone.
  1. Try a new screen. This touch issue may be to do with a damaged screen.
  2. Put in a new battery. A really old battery might be the issue as to why you need to heat up the phone to get it working.
# If this fails it is probably a motherboard issue. This is a pricy repair, so you are probably bette of getting a new phone if this is the case.
  1. Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shreya Kumara 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 25
总计 1,007
