跳转到主内容
MSI GP60 2PE Leopard released in 2016. The model number is GP60 LEOPARD-010;9S7-16GH11-010.
6 个问题 查看全部
games are running very slow. what can I do to fix this?
so first, not that it matters a ton i imagine, but my laptop is an MSI GP63 Leopard 8RE. (wasnt in the choose device section.) i am having troubles with running games. they will either lag a lot or they will run so slowly that i really cant even play them. this laptop is more than capable of running these games, has almost nothing on it memory/storage-wise. so im really confused on why it cant run games very well. i believe i solved this somehow way back when, but now having these problems again. any help is appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
What games are you running and what are the specs of your specific machine?
完成的
添加一条评论
1个答案
Try to clean cooler at CPU and GPU with alcohol wipes gently. Replace with new thermal paste . Update GPU driver. If using windows 10, you may also setup on storage sense.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gage Riesselman 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 12
总计 408
