跳转到主内容
Guides and repair information for Ninja blenders.
128 个问题 查看全部
BL481 Ninja Blender No sign of power getting to blender no lights
This blender has not even been used (well, sort of, Amazon refurbished, not used since i got it). I waited too long to try it out and warranty is up. I plugged it in, hit start/stop, no lights, sound, nothing, so not about arrows not lined up, or things not placed properly. I’ve also tried multiple outlets that all work fine otherwise,, so not that. I just need to know where to even start to troubleshoot this once I open it up, assuming that’s where I need to start. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi,
Do you have a DMM (digital multimeter) and know how to use it?
If so, disconnect the blender from the power and then connect the DMM (Ohmmeter function) across the two power pins on the power cord plug and check if there is a reading on the meter.
If there is no reading then as you will have to open the blender anyway first check that the wires in the power cord have continuity from the plug to where they connect in the blender.
After that inspect the blender circuit board for any possible problems, e.g. loose connections or burnt out components.
If none visible then it is a matter of tracing the wires from the power cord connection point on the circuit board through the circuit board using the meter.
I cannot find a service manual or a schematic for the blender so it may be a case of point to point testing using the Ohmmeter until the problem is found.
Usually a no power problem is at the front end of the board where the power first comes in and not deeper into the circuit e.g. fuse, surge suppressor etc
If you haven’t got a DMM or even if you have then post some close up images of the circuit board back here and hopefully something may be spotted that you missed.
Here’s how to do this.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Amy Thomas 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 18
总计 137
