1.25 in spring strap fell out after repair.
This is a spring with 2 small mounting holes with a slotted end.
Hi @sandy430 ,
Without an image it will be difficult to identify it and where it belongs, if indeed it does belong in the laptop.
Here’s a link to the hardware maintenance manual for the laptop.
It doesn’t mention or show the spring in the parts section as a separate part so maybe you’re right and it doesn’t belong in there.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 69
6条评论
Hi @sandy430 ,
The make and model number of the tablet would go a long way to getting a helpful answer
Adding an image of the spring to the question would also help.
Here's how.
在已经存在的问题里加入图片
由 jayeff 完成的
I added a second HD. The unit seems to work ok
由 John Iwaniec 完成的
Lenovo Flex5-1570
由 John Iwaniec 完成的
No picture. the two mounting holes appear to from a pressed mounting. It has sight hump with the slot at the other end.
由 John Iwaniec 完成的
I found it on the work table with the reassembly. May be from something else. Sorry
由 John Iwaniec 完成的
显示更多的1条评论
