跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iPhone keeps restarting while not charging
My iPhone 6 restarts randomly and starts boot looping. Sometimes it immediately restarts when unplugged, sometimes it takes opening an app, opening the control center or just doing something in any app. When it is charging, everything works like normal, and it stops boot looping if it currently is. The battery was replaced in 2016 at a third party repair store, and worked until recently. Last December I noticed that the left side of the device was bent open and could not be closed, and inside it looks like the battery is thicker than normal, stopping the device from being closed. I didn’t notice any other damages or anomalies, not even anywhere on the battery. Should I simply replace the battery, or are there any other possible causes?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
You definitely need to replace your battery. After a few years they can no longer deliver the right amoutn of power the phone needs, so it will do odd things like restart, bootloop, etc. Since the battery is bulging, i would highly suggest to not charge or use it until the battery is replaced because it is unsafe.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Korbinian Rest 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 74
