跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
Touch Screen Behaving Weirdly
In a fit of anger, I pressed down on my iPhone 5c’s screen, probably harder than it was meant to handle. Afterward, the touch screen started behaving weirdly. It wouldn’t respond when I touched it. It began pressing in random places on the screen, sometimes opening an app or something. The keyboard would sometimes not work on some keys, and often press the entirely wrong ones (e.g. pressing L and typing a Z). Sometimes the issue goes a way temporarily and I am able to use it like normal. I have tried closing all apps, I have rebooted numerous times, and have done a couple hard reboots. None of these had any impact on the issue. I am certain this is a hardware issue. If anyone has any words of advice, that would be much appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Sounds like you’ll need a screen replacement. You most likely damaged the digitizer which is what senses your touch. When that get’s damaged, it can cause issues like the ones you’re experiencing.
这个答案有帮助吗?
得分 1
4条评论:
I ordered a replacement screen on Amazon. Hope it goes well.
完成的
Don't use screens from Amazon, eBay, Craigslist, or AliBaba. They're junk.
完成的
It seemed to have mostly positive reviews. What's not good about the ones from Amazon?
完成的
@s0me0ne most of the time they're junk and they don't come with a warranty.
完成的
添加一条评论
I have had the same problem but with an iphone 6s what I did was I took out the battery and put it back in and then it worked just fine.Sorry if it doesn’t work for you :(
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
S0me0ne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 106
