跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
678 个问题 查看全部
iPhone stays on apple logo and turns off after housing repair
I have replaced the housing of my iPhone 8 plus. When I start it up it shows the apple logo and after a few seconds it turns off. After a few seconds it turns on again and this goes on and on. Does anyone have any idea why this is happening and how can I fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
When doing a housing replacement, a lot of things can go wrong and it can be hard to figure out what is causing the issue. You need to reduce the number of variables.
I would start by testing a bare-bones setup. Start by disconnecting the battery first (always!). Then disconnect the digitizer, LCD, charging coil, front camera, rear camera and home button extension flex. Now re-connect the battery; you should only have the battery and Lightning Dock flex connected. Connect a known-good, preferably Apple-original Lightning cable to an iTunes enabled computer.
Does iTunes recognize your phone? If so, then you should re-connect one flex at a time until the phone stops working. I would start with the charging coil, then the Home button flex, then add the rear camera, LCD & Digitizer.
If the bare-bones setup does not get recognized by iTunes, then you most likely have a logic board issue. You could send it (or find a local) to a repair shop that specializes in micro-soldering repair.
这个答案有帮助吗?
得分 3
1条评论:
I have tried it like you said, iTunes recognizes my iPhone. But when I connect the flex for the lcd it stops working.
完成的
添加一条评论
Now when I plug it in my pc iTunes comes up and says that it has to set the phone to factory settings. After the phone has been installed to factory settings iTunes wants to do the same thing again. I also tried other LCD’s but and that also doesn’t work.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tunahan Sen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 538
