跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Error 14, can't exit Recovery
I have a problem with my iPhone 6s+.
It started when my phone started to be slow. I rebooted it, and it got stuck in boot loop (apple logo). I then tried to put in in Recovery Mode and update it via Mac/PC (It did not have the latest iOS). The upgrade failed halfway through with Error 14. I then opened the iPhone and disconnected the LCD etc., but still Error 14 when trying to upgrade. Now it is stuck in Recovery Mode.
Any idea what to do? I would hope not to lose my data, if possible…
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
At this point in time the only solution would be a restore as the error 14 usually means your NAND is full or corrupt. There have been some cases I have seen where faulty parts or IC has caused this but that is extremely rare.
The apple operating systems get larger in size for every update so if you have a lot of data on your phone and it hasn’t been updated for a while this problem will occur.
All as Apple have to do is leave a signed skeleton IOS for this situation but they never will. I always advise people who encounter this problem and haven’t backed up there data to put there passcode and phone in a draw as I know people are working on a solution for this error.
这个答案有帮助吗?
得分 3
2条评论:
@imicrosoldering
Thank you for that information, Chris!
Before I did the initial reboot I checked the free space and is was about 800 mb if I remember correctly, so your assumption could be very much possible!
Do you know anything about the timeframe for that workaround (weeks or months or years...)? I would then weigh, the loss of data against not being able to use the phone for that period of time...
Thank you again!
完成的
@cryptomaniac I think it will be a long time coming unless Apple addresses the issue.
完成的
添加一条评论
添加你的答案
Crypto Maniac 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 24
总计 977
