My UP6/E Marco pump is passing water into the electric motor.
Does anyone know how to get replacement part numbers for this water pump? I have the parts breakdown diagram, but it doesn’t show part numbers.
I'm not sure if the "x" shown against the parts in the list means that they are available or that they are not available. To me that is a bit ambiguous as it could be read either way. Also as you say not having a part number for each part doesn't help.
Perhaps you could contact Marco and ask if the parts that you require for the pump are available or not and if so, where they can be obtained from in your location.
You can only ask and see what the response is. It never hurts to ask and only takes a little bit of time to do.
Hopefully you will get a positive response.
这个答案有帮助吗?
Hi Thomas,
spare parts are available for all products on www.marco.it but you need to register to the website to be able to see them.
A replacement kit for the UP6 lip seal is available with code R6400094 and costs ~10$ excl. shipping.
If the motor is not permanently damaged you can follow the next steps to try to refurbish the pump.
You can open the pump using this guide:
After this, you have to:
Please, make sure that everything is completely dry before assembling the pump: it’s watertight and therefore what’s in, remains inside!
After these operations, you’re ready to put the pump back in place, as described in this guide:
For any technical question, there’s Zendesk at support@marco.it
Hope this helps!
指南
难度:
简单
5 minutes
指南
难度:
简单
10 minutes
这个答案有帮助吗?
Hello, I had the same problem with my up6/e for 2 times in 7 years of use, both the times I had the pump repaired for free by sending it to Marco, Italy.
After the last time, I decided to change the position of the pump, which was operating vertically, to the horizontal setting. At Marco, they say it shouldn’t matter, but the problem happened two times on the bearing supporting the weight of the rotor.
Hope this helps
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 271
