跳转到主内容
加入维修社区 - 创建账户
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
My iMac won't boot at all
Hi.
I have posted in Apple discussion, found no solutions with software. I think something must be wrong with hardware — was working fine yesterday, then must’ve updated (maybe overheated some part?) and now it will only show a white screen when I click the power button. No chime, no logo, no keyboard input either (using a wired keyboard). So can’t access safe mode, recovery, alt disk, NVRAM reset, anything. Resetting SMC doesn’t work either. I would maybe be willing to replace a cheap part but hope not to buy a new one. Any ideas? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
PROBLEM SOLVED:
Issue — hard drive!
(Actually, relatively new SSD, but whatever!)
这个答案有帮助吗?
得分 0
添加一条评论
Have you tried to hold command+alt+R ?
这个答案有帮助吗?
得分 0
5条评论:
I just did and…..nothing :(
完成的
Try holding shift +control +option (while connected to power source) for 3 seconds the power on ...
If not try holding command +R and boot to safe mode
完成的
Seems like a corrupt OS or impartial download that’s causing this
完成的
Hope it isn't hardware, but it will literally not do anything no matter what keystrokes I press..........and smothering the keyboard doesn't work either ;)
完成的
However the USB ports are providing power. The DVD drive engages when the computer turns on. But no chime, no sign of life besides the blank white screen.
完成的
添加一条评论
添加你的答案
Harrison Gordon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 185
