跳转到主内容
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 个问题 查看全部
Can’t download the additional components
Was trying to sell old MacBook Pro 2011, followed a video to reset using command r upon restart all worked fine till got this message after trying to re install Mac OS X Lion , “ can’t download the additional components needed to install max OS X”
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Did you solve this? I have the same issue
完成的
添加一条评论
3个答案
最有帮助的答案
Try using internet recovery (Command + Option + R) instead.
这个答案有帮助吗?
得分 1
1条评论:
we have MacBook Pro from 2015 and it was failing exactly in the same way. On Apple web was to press "Command + R" and i had followed the Guide, but when i tried your advice "Command + Option + R" there was brand new version of the guide and it worked.
So people : try (Command + Option + R) instead.
完成的
添加一条评论
Seems there’s an answer here: re installing OSX problems. May be linked to outdated certificates, and the only way I think you can solve this is by creating a new installer on to a USB key, or by (somehow) setting your clock back before you install. I couldn’t figure out the clock option since I already formatted the system, so I am trying the USB route.
这个答案有帮助吗?
得分 1
1条评论:
The clock can be set from an external bootable drive (making sure you aren't connecting to the Internet's time server - Unplug your Ethernet or WiFi connection) when using the USB bootable installer. Or using the a terminal session Changing system date from Terminal – OS X recovery
Trying to access the Apple servers over the internet to do the internet recovery will cause your system to access the time server (resetting the date to the correct date) so you can't get the OS installed.
完成的
添加一条评论
While solving the same problem, I solved it with the solution methods given on the page. maybe it will help you
https://www.knowerstech.com/cannot-downl...
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
mando hernandez 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 54
总计 8,077
