跳转到主内容
1.83 GHz Core Duo 处理器 或 1.83, 2, 或 2.16 GHz Core 2 Duo处理器 A1208 (EMC 2104/2110/2114/2124)
201 个问题 查看全部
With upgraded T7600 2.33Ghz chip can I install an SSD?
I have ordered a T7600 2.3Ghz Socket M chip upgrade. I would ideally like to also upgrade the hard drive to a 500 GB SSD. I have 2 concerns (1) possible lack of fan cooling capacity and (2) SATA 3 upgrades are everywhere yet this imac is SATA 1 (slower write speed of 1.5 Gb/s) and so not sure if it will work. I know will have to use a 3.5 inch to 2.5 inch adaptor. Please can you advise me.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Physically you have the right idea!
You need a drive converter from 2.5” to 3.5” like this Icy Dock EZ-Fit Lite Dual 2.5" to 3.5" SSD/HDD Mounting Bracket You’ll also need to get a drive which offers compatibility like Samsung 860 QVO. As we can see under the Interface line: SATA 6 Gbps Interface, compatible with SATA 3 Gbps & 1.5 Gbps interfaces are all supported! Make sure what ever drive you get lists support for the older SATA I (1.5 Gb/s) standard. Here’s the needed guide: iMac Intel 17" Hard Drive Replacement
You will need to make sure you’ve got the newest OS your system supports installed - OS-X Snow Leopard 10.6.8
You should also get TRIM Edabler as Snow Leopard don’t not offer TRIM services natively.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
frandech 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 50
