跳转到主内容
加入维修社区 - 创建账户
Phone won't charge over 1%
Hi recently (before Christmas) I bought a second hand p20 lite for a very attractive price. Then the issues started. The selfie camera got covered in dust very quickly. The phone loves acting up and slow down when I need it the most. But most importantly recently it hasn't been charging very well. I've tried different charges and nothing helps. Finally the piece of rubbish just decided to stop charging. It's stuck at 1% and sometimes even jumps to 0% and then back up to 1%. I am almost certain that it's either the battery or the charging port however I would like to be sure so I don't pay twice for replacements.
Also just so you guys know I have not dropped the phone, haven't put it in the water etc. I've used different chargers and charging cables. I've cleaned the charging port. The only thing I haven't done yet is getting inside of it. Thanks for any help guys
Edit:
Also I forgot to mention that the charging port is not loose and the cable “clicks” in but I have to admit it looks kind of bent from the top (screen side). It's my first encounter with the type-c port so I don't know if it's meant to look like that
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
when it comes to mobile phones repair, you must be able to take voltage readings with either opening the phone and using probes or using a usb ampmeter to verify voltages being input to the phone. without these tools, you will never know if it truly is not taking any volatage for charging or anything else.
do you have these tools? are you able to buy them/borrow them? if yes, please let me know what voltage and amps it is drawing.
If not, unfortunately you will need a technician, or replacement.
这个答案有帮助吗?
得分 1
1条评论:
I think my dad has something like that I'll try to nick it for a few minutes and see what it comes up with. Thanks for the info brother
完成的
添加一条评论
Get a new charger……..
这个答案有帮助吗?
得分 0
1条评论:
Mate I could write you a novel about how many different chargers I got but I already mentioned that in the description...
完成的
添加一条评论
I rebooted and problem fixed. This happened to me also. It could also be that you need a patch or update.
Best of luck to you!
这个答案有帮助吗?
得分 0
1条评论:
My p20 jus stuck on logo screen and also charging screen. I have tried everything on YouTube still nothing
完成的
添加一条评论
添加你的答案
Klaud 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 38
总计 5,159
