跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
468 个问题 查看全部
touch keeps going after screen change
hi I have changed a screen on a iPhone XR, have used the supplier and XR screens before and never had a problem. the phone was working fine, then after 4 days the customer turned the phone off and then touch stopped working. I did a force restart and the touch works fine, once the phone is turned off the touch stops responding again. a force restart and it works fine again. everything seems fine, I also used a icopy to copy over from the original screen. cant find what I am missing? any help pls
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Obviously, you’ll want to double check your work and insure there isn’t any damage to the screen or flex. Even with the best suppliers, you will get an occasional dud screen. Try installing another screen to see if it solves the problem.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
dan morrill 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 53
