跳转到主内容
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
142 个问题 查看全部
问题已关闭
Super Drive no longer working after ram upgrade
Replaced ram modules in Mac Mini with no problems, and mac starts ok and recognizes new memory configuration
but, now the super drive does not work (i do not know for sure that it worked prior to ram upgrade).
questions is: is there any thing in the upgrade process that could have caused the drive to stop working. have checked the mother board/daughter board connector several times (and other connectors)?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Try re-installing the old OEM ram back in the unit. If this fixes the problem, then there is reason to suspect the RAM. But its been my experience that it's usually just a bad optical drive that will need replacement. They are known for going bad in several of the early Intel and G4 models as well.
这个答案有帮助吗?
得分 0
添加一条评论
There is a ribbon cable in the mini that connects the superdrive. It is really easy to dislodge this when changing the ram. I disloged it a few times myself. Just check the back of the board with the super drive and I'm guessing that the cable just popped out of the socket. Just put it back in and secure using the side clips and you should be ok.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 769
