跳转到主内容
发布于2018年9月21日,型号为A1921,A2101,A2102,A2104。支持GSM,CDMA / eSIM或 nano-SIM / 拥有64,256或512GB容量可选 / 有银色、金色、深空灰可选。(读作iPhone 10XS Max)
375 个问题 查看全部
Best way to clean iPhone XS Max logic board?
I recently purchased an exploded iPhone XS Max and managed to remove the logic board. Unfortunately it was covered in carbon particles so I put it in some 99.9% isopropyl alcohol for about 20 mins and used a toothbrush to try and clean it. It hardly worked at all and now I’m kind of at a loss for what to do. Do I keep trying the same thing over and over again? Is the board already beyond repair? Thanks for the help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The picture is a little bit blurry so it’s hard to see what the residue looks like. IPA and a brush is usually effective but some times you need to brush over a dust-free wipe, such as a Kimwipe, to actually lift any floating residue. If the carbon residue is “baked-on”, then something stronger may be necessary but you have to be careful what you use as you don’t want to damage or corrode the elements of the logic board. Maybe a chemist can hop onto this thread.
A shop could probably put the board through an ultrasonic bath which would certainly be an improvement. At some point, if the board doesn’t work, the shields should probably be removed for a proper “full” cleaning.
这个答案有帮助吗?
得分 3
添加一条评论
You will probably need to use a mixture meant for removing carbon particles from metal, if you want to clean it off.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
WowCool1354 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 7
总计 312
