Spilt protein shake, got into bottom speaker grills and charging port
My shake spilt in my bag and got into the bottom ports of my iPad. It's sticky and hardened. How can i clear out the charging and speaker ports? Would Apple be able to help?
Apple won’t help you in this case, they will only suggest an OOW replacement.
I would try a toothbrush and some IPA to clean out the grill. As for the charge port, you could try the same but you may have to pick at it (very gently) with a toothpick. Be very careful as there are some small metal pins inside the charge port and if your not careful, you can bend or break them. This would be come a more complex repair…
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 192
