跳转到主内容
Repair guides and support information for Azpen tablets.
38 个问题 查看全部
Azpen A1046 will no come on
I bought my husband a Azpen A1046 and it will no come on . The trouble shooting page says to reset by inserting a paper clip in reset hole, but doesn’t say where it is on the side..
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi,
Is the tablet indicating that it is charging or charged when you just connect and switch on the charger to the tablet?
Just verifying that you are holding the tablet’s Power button for 3 seconds when you go to turn it on, is this correct?
Here’s a video which shows here the reset hole is located in an Azpen A1040 which may help. It is seen at 0:42 seconds into the video. I realize that this is not your model but it should be close enough.
It is a recessed button switch in a paperclip sized hole. You should feel it operate when you gently insert an opened paperclip
这个答案有帮助吗?
得分 1
2条评论:
The hole on mine that somebody said was the reset hole is marked on mine as being the mic.
完成的
@Bobby Harger
What is the model number of your tablet?
完成的
添加一条评论
Hello I bought a azpen tablet model number A1046 on the Facebook classifieds and it's skiing for a 4 digit pin number I don't know I have hard factory reset and still not able to use what can I do to get into the tablet to work
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jkwat1 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 547
