Touch Bar seems to be disconnected from system (Help wanted)
So yesterday I accidentally dropped my mac and after that, the touch bar was not responsive at all, and I check the accessibility settings to only not find any touch bar zoom settings at all. From what I know, it seems like the touch bar was completely disconnected from the system, and does not function anymore. Is there any possible way to fix this problem?
(Another thing that keeps happening is that the system crashes after trying to wake up from sleep. I think the drop has also caused some other possible problems)
4条评论
I honestly have the exact same problem ,did you manage to figure out what was the fix?
由 david 完成的
@davviiiid_ I think repair could be the only way to go. If you are experiencing crashes after wake up, it could be the same problem as I had. I no longer have this problem anymore.
由 Jackson Chen 完成的
ah thank you , did you just replace the touchbbar or the whole top case?
由 david 完成的
@davviiiid_ just the touch bar. with other broken parts too.
由 Jackson Chen 完成的
