跳转到主内容
加入维修社区 - 创建账户
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
Is it a Faulty Taptic engine?
I began to realize a month ago that my iPhone XR began to vibrate/haptic feedback on its own. For example, when I’m reading an article on my phone, I can feel that the iPhone made a slight vibration/haptic feedback. But the problems does not always occur. It only happens a couple of times a day.
Is it because I drop my iPhone? Or is it normal?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The taptic engine is pretty robust but when phones “drop”, it can have unpredictable effects. Plus, the newer X series phones are much heavier so the force of the impact is much higher than with a lighter phone.
From this vantage point, it’s hard to say if the taptic engine is the problem or not. It could be a loose connection or even a logic board issue. You’ll have to take a logical approach and change one variable at a time. Start by opening it up and looking for loose connections. The next step would be a replacement taptic engine. If those steps don’t solve the problem, it could be a logic board issue.
If the problem coincides with an iOS update or installation of a specific app, then it could be software related too.
这个答案有帮助吗?
得分 2
1条评论:
But the problems does not always occur. It happens a couple of times a day. What do you think?
完成的
添加一条评论
添加你的答案
Carlo Jovic 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 799
